New Graphics card recommendation on par with GeForce 9800GT
retroborg
Until now I was using an Albatron Geforce 9800GT 512MB card which I bought for ~100euros back in 2009.
http://www.mwave.com.au/productarchive.asp?sku=42050318
What was good about this card is that it had a 256bit memory bus / interface and pretty much every 3D game played nice and fast on high graphics settings @1280x1024 resolution (Aliens VS Predator 3, Rage, Command & Conquer 3 & 4, Duke Nukem Forever, Black Mesa Half Life Mod, HL2, etc...)
How ever it got toasted the other day, so I now I want to buy a new graphics card of at least equivalent performance and similar price range to play the upcoming Doom 3 BFG and some of the upcoming games. (Preferably nvidia as their drivers are better)
I checked the current nvidia cards, but noticed that all the cards of that price even though they have better & faster GPUs and more & better video RAM (DDR5 / 1GB/2GB), their memory bus / interface goes only up to 128bit or 192bit the most, which I imagine will bottleneck these cards.
Also I noticed that none of the current GFX cards feature a TV-Out output to connect my old CRT TV via Scart or RCA and I don't want to have to buy a new LCD/TFT TV.
My PC specs:
Intel Core 2 Duo @2.4GHZ
4GB Ram @800MHZ
Windows 7 32Bit
19" 4:3 TFT Eizo S1931 Monitor @60HZ
My motherboard Asus P5B-E:
http://www.asus.com/Motherboards/Intel_Socket_775/P5BE/#specifications
Features 1 x PCIe x16 slot to connect a GFX card on.
So which card should I get to cover my above needs?
Thanks in advance.
DaveSimmons
40,730
670
Look at benchmarks, not at the memory bus width or the amount of RAM.
For the exact same memory type at the same speed, 256 > 128. But RAM speed can make up for that, and the GPU power might be more important than the RAM bandwidth.
The only thing to be careful of is that a card review might show performance with fast GDDR5 RAM while a budget version of the same card number might use cheaper and slower GDDR3 instead.
Then it might make the most sense to buy a used older card with TV-out as a replacement.
