new Firmware upgrade problem
Jimbd
56
When I try to flash the bios with the new firware utility in Win 98se and Win 2000(dual boot)
for the Ricoh MP9120A DVD/CDRW drive firmware 1.3 (current is 1.1)
It says "unable set the drive in Up Mode"
"please select tareget drive" . the firmware is not getting upgraded. I have not set the DVD region yet.
What does it mean and how to upgrade the firmware the problem?
Jimbd
56
Dave, thanks for your response i could really use some help here. I also need to flash the region free flash as well (that later).
No, nothing is connected to that ide channel. I use a Abit VP6 dual cpu motherboard with ide raid(not using raid config though).
So my ATA -100 hard drive is on a 80 pin cable as IDE 3 and the Ricoh MP9120A DVD/CDRW drive is on the seperate channel/cable as ide 1 as Master.
Does one assume this should be as slave ?
