You should of enabled ahci before installing win7, try again.
Yep, finally got it working after enabling and installing the Win7 AHCI drivers in the registry. Now, I've got a problem of disappearing secondary hard drives (Samsung F1 and F2 750GB/1.5TB) whenever my computer wakes from sleep. Googling around led me to setting the sleep timer to 999, which worked for a bit buy my HDs still intermittently disappear.
Is there an updated AHCI driver out there from Microsoft? I've had conflicting google searches saying using the Intel Storage Manager update doesn't support TRIM.
People who are getting >400 are using the 160GB drive with the firmware update - the 25mb/s sequential write improvement does help with the score, but it's not that useful in real life.
Other than that, your 4k write is really low - I get ~40mb/s with my 160gb G2 drive. Did you use the drive some time before upgrading the firmware? I had to run the manual TRIM tool once after I upgraded to get the full performance.
QX6700 OCed to 3.2ghz with 80GB G2
i7-975 OCed to 3.73ghz with 160GB
Are you getting over 430 because you OCed to 4ghz?
It seems the benchmark really favors the 4k results, 8mb/s more 4-threaded write, 26mb/s more sequential write, but 4mb/s less 4K write and I get 5 points more.
Don't know why the scores are lower then. Both machines are running in AHCI mode using Microsoft driver, running in Windows 7 Enterprise 64-Bit. Both SSDs are using approx. 35GB of space.
I ran the optimizer and it only took like 1 sec is it suppose be this fast or it didnt optimize at all?
So here are some basic installation questions...
I have a new G2 drive with nothing installed on it. I plan to install Windows 7 x64.
Should I first install Windows 7 then do the Intel firmware update? -or-
Should I install the firmware update first, then install Windows 7?
For people burning the ISO to a CD, is this the only way to update the firmware, or can this be done in the Windows environment?
Is there any way you can buy a new Intel SSD with the updated firmware already on board? I know the Vertex drives shipped after late October all have the proper TRIM on board but I really would like 80GB and OCZ doesn't make that size.always, always, always update firmware first... regardless of the hardware involved (mobo, SSD, whatever)... first you upgrade firmware THEN you install OS.
Although it often doesn't HURT to do it the other way around, it is smarter and safer to do firmware first.
Installing the INF gave me a boost. CrystalDiskinfo still reports TRIM as active, hoping this is the truth...![]()
What INF are you talking about ?Installing the INF gave me a boost. CrystalDiskinfo still reports TRIM as active, hoping this is the truth...![]()
I'm seeing similar results to you - our 4K Write speeds are around half what other folk are seeing.Also I´m not sure I´m getting correct speeds from my SSD, I´ve just installed, no tweaks whatsoever, any tips for improving speeds? I´ve seen many people getting over 400 total score.
