- Feb 20, 2001
- 1,388
- 0
- 0
The Coates Engine. The spherical rotary valve system is made up of spheres rotating on a shaft sandwiched between a split head. These spheres are either chain or belt driven via the crankshaft, much like an overhead camshaft. Each sphere rotates against a matching seal between it and the piston, one for intake and one for exhaust. The spheres have cavities and ports machined into them for the induction of fuel and air on the intake stroke, and the evacuation of fired gases on the exhaust stroke. This design performs exactly the same function as poppet valves, but the design eliminates the poppet valves, valve springs, guides, camshaft, pushrods, rocker arms and other smaller parts. The Coates engine operates with over 100 fewer parts than convention engines.
Advantages include:
-Lower Emissions
-Better Mileage
-Reduced Lubrication Requirements
-More Power
-Reduced Noise & Vibration
-Adaptable for Alternative Fuel
-Reduced Manufacturing Costs
Man this engine looks REVOLUTIONARY! 14,000 RPMs! This looks to be the engine of the future. More information at their website:
http://www.coatesengine.com/index1.html
pictures:
http://www.coatesengine.com/eGallery/images/pic03.jpg
http://www.coatesengine.com/eGallery/images/pic06.jpg
http://www.coatesengine.com/eGallery/images/V-8engine.jpg
http://www.coatesengine.com/eGallery/images/components.jpg
