Finished building a computer today, and being relatively new to building computers, I have come across a problem that has stumped me.
I have 2 IDE drives: a 48x Optorite CD-RW and a 80GB Maxtor HD
The CD-RW isn't being detected so I can't install windows XP.
I'm pretty sure the CD-RW is on Master, on the back of the CD-RW it says:
CSM
SLA
The pin thing is currently on M and A.
I'm guessing that's master...but the CD-RW still won't boot.
I'm using a ribbon cable that has 2 IDE connectors, so you can hook 2 drives up to this ribbon cable. Should I use the 1st (the one closest to the thing that will plugin to the mobo) or the 2nd?
I'm on an IC7 for the first time so if im not sure if i need to do something in the BIOS to get it to detect or not. The HD IS detected btw.
Could i have the ends of the ribbon cable mixed up?
Is my win xp cd messed up?
Master setting wrong? Should it be in master?
etc, etc.
Thanks for the help, any suggestions/help at all is appreciated
BTW, it says DISK BOOT FAILURE, INSERT SYSTEM DISK (or something very similar) when i turn the computer on and don't go into the bios and just wait for windows setup to try and load.
Green light on the IC7 turns red when i turn the computer on and i hear a little beep...all of my RAM is accounted for though so i'm not sure if the light/beep are normal, possibly ram related, or related to this problem
EDIT: Moved, sorry for the messy post
CSM
SLA
etc, etc.
