New Computer Power Supply Question
dmoseder
I don't know really understand the 12v rail thing, do you add up all of them and if its over the graphics card amp requirement its ok?
But anything I was woundering if you guys could tell me if this power supply will do for the computer i'm building:
http://www.newegg.com/Product/...x?Item=N82E16817256006
Q9470 CPU
2x Radeon HD4870
2x SATA 3.0GBS
ASUS P5N-D LGA 775 NVIDIA nForce 750i SLI ATX Intel Motherboard
4GB DDR2 800
Thanks!
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
Have a look here in the sticky: http://forums.anandtech.com/me...=2167846&enterthread=y
+12V rails are NOT additive because the "rating" is only an indication of the limitation of power being delivered down a group of connectors. Your actual +12V capability is on the label in a place designated as "+12V Combined".
On the SilverStone you link, it's 720W, or 60A. Note if you were to add up the +12V rails you would actually get 72A! A much much higher number.
