I built a PC yesterday and there have been some problems. The components are:
Motherboard: ASRock H55M Pro
CPU: Intel i5-750
GPU: XFX Radeon HD5770
PSU: Silverstone ST50F-ES
RAM: Corsair XMS3 PC3-12800 2x2GB
Drives: Samsung Spinpoint F3 1TB, LG DVD Burner
After assembly was complete, I plugged it in and turned it on. I briefly saw the BIOS splash screen, then powered down to put the side panel back on the case. Since then, I have been unable to get any video signal from the PC. (DVI to Dell 2005FPW)
When I press the power button, the CPU, GPU, and case fans all spin, the motherboard does NOT beep, and everything turns off after several seconds and automatically turns back on several seconds after that. I don't know how long this cycle would continue if left alone as I've only let it turn off and back on once at a time. If I remove the RAM, the motherboard does beep to indicate the POST failed, so I can't tell if, with the RAM properly inserted, the system is POSTing successfully or not.
I have an old AMD Socket 939 PC lying around which I've been using to help troubleshoot. I tried my ATI X800XL from the old PC in the new one but got the same result. When I tried the new XFX card in the old PC, however, it wouldn't even POST, although it works fine and boots windows with the old card.
If the new video card breaks the old computer, I would expect it to be the problem, but the old card doesn't work either, so I'm just about stumped. Any ideas?
CPU: Intel i5-750
