1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
I mainly want to build a computer for gaming purposes and watching HD video. This will be my first build and I have no experience on where to even start. Only through little research have I found this website, which is overwhelming me with information at the moment.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1,200.00
3. What country YOU will be buying YOUR parts from.
United States
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I've always bought Intel and nVidia with my pre-built computer systems in the past and have had no complaints. Those are the only two companies I really know anyway.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
All new parts, excluding the mouse and keyboard.
6. IF YOU have searched and/or read similar threads.
I've looked at threads, but have no idea on what I'm really looking at.
7. IF YOU plan on overclocking or run the system at default speeds.
I have no idea on how to overclock, so default speeds.
8. What resolution YOU plan on gaming with.
I am guessing this will depend on my monitor? Right now I game on 1280x800, but I'm assuming that's out of date.
9. WHEN do you plan to build it?
Within the next couple months
I'm asking for advice on where to begin and what parts to start with so I can go from there. I know everything needs to be compatible and I am going to take my time building it. If it takes me 3 days to get it together, that's fine. I'm in no hurry and plan on learning a lot through this process.
I know that this might seem like a waste of a thread, but hey, we all got to start somewhere. Thanks.
$1,200.00
United States
