New category of cooling fan noise or loudness level
tcsenter
18,949
575
This seller is helping to really improve on the often difficult to understand 'technical' sone or dBA metric used to specify the potential noise level of a cooling fan when operating. I approve of this proposed rating system:
SuperRed CHD9212EB-AH 9038 9238 90mm 9cm 12V 1.30A violent fan
1.3A!!
No doubt left here. It communicates to the user, WARNING, this fan may kick your azz! :D
VirtualLarry
56,587
10,225
I figure that's in the category of "finger-chopper" fans, and to be careful around them.
tcsenter
18,949
575
Hey only ~5K RPM, still not as fast as those 6K RPM "Delta" fans that were popular with overclockers back in 2000 ~ 2004. e.g.
Reactions: Ajay and Pohemi
aigomorla
21,108
3,631
I sir challenge your challenge.
These are counter spin server pizza box fans.
Basically 2 40mm fans sandwitched together, where one counter spins.
Its a total of 1A.
But @ a nice quiet 72dB.
There is also this bad boy but its not really a PC fan....
Reactions: tcsenter
ElFenix
102,404
8,575
i had one of these. could hear it from the next room. athlon 1700+ with a swiftech mcx screw-pin heat sink
aigomorla
21,108
3,631
oh man i thought i was the only one who had one of these guys...
I went for a more quiet approach tho.
They were called The MCX-Vcore
mindless1
8,784
1,774
Yeah there are faster spinning fans, but at 90mm and 38mm thick with 1.3A, this one is right at the threshold of being able to take off a small finger... depending on how sharp the blades are.
I'm glad we're past the era where (stock speed) consumer applications need fans spinning that fast... though I'm overlooking video cards.
Reactions: tcsenter
Ajay
16,094
8,114
Yes, I had a couple. Nicked a finger on one. So glad when Thermalright came out with their full copper finned HS that took an 80mm fan - this time I used finger guards still high RPM, but not like the damned screechingly high pitched 60s).
mindless1
8,784
1,774
^ Those and the pin finned aphas with 80mm fan, were the era where I was finally able to keep fan speed below 2500RPM avg, while still overclocking. Granted, temperature became the o'c limit, but I didn't want to blow the mobos up and this was the socket A era when mobos were still notorious for blowing capacitors.
Reactions: Ajay
