new case help
hardcore_gamer29
958
24
hi i need a case with good wire management please suggest some cases my rig only cooler master and corsair
i5 2500k
asus b75
asus gtx770
seasonic x650 gold
lehtv
11,897
74
Where are you buying from and do you have a budget?
I'm assuming you want an ATX case, not microATX. Though your motherboard might be microATX (as so many B75 boards were).
Why only Cooler Master and Corsair? There are plenty of other decent brands, many of the better than Cooler Master and Corsair.
UsandThem
16,068
7,383
I know this might sound rude, but here it goes anyway.
If this is like any of your other many posts, people will suggest a component, you will reply with "But I'm from India and it's too expensive".
Just look at what's available to you in your region at your budget, read a review on the one you like, and pick one. If you find one you are considering buying, you can ask us if it's any good. We can't blindly go through every Corsair or Cooler Master case available in India.
Reactions: lehtv
hardcore_gamer29
958
24
yes you are right bro i am from india so i am considering corsair carbide spec01 coolermaster k380 which one is better i need cable management and any other you would like to suggest please do
hardcore_gamer29
958
24
will i be able to use big fan for my cpu i am gonna get corsair carbide spec 3 tomorrow
UsandThem
16,068
7,383
Not sure. Corsair's website will list the allowable max height of the CPU cooler, and the CPU fan manufacturer will list it's height under the detailed specs.
Without knowing what the CPU cooler is, all we can say is 'maybe'.
Valantar
1,792
508
That case supports CPU coolers up to 157mm. In other words it won't fit a Hyper 212 Evo (159mm tall), Noctua NH-D15 or U14S (165mm tall), U12S (158mm tall), or a Cryorig H5 (160mm tall), but it will fit a Cryorig H7 (145mm tall). Now I'm tired of googling CPU coolers for you - I came up with this in about two minutes. It really isn't hard. You can figure this out.
What I'd do:
  • Google "Best tower CPU coolers," find some roundups.
  • Google your options individually, look up specs, and find which ones are <157mm tall.
  • Discard taller options.
  • Check your local retailers/etailers, discard options that aren't available.
  • Find reviews of your final options.
  • Make a choice.
It really isn't difficult.
hardcore_gamer29
958
24
What I'd do:
  • Make a choice.
thanks i got carbide spec 02 today
Valantar
1,792
508
Well, the maximum cpu cooler height for the spec 02 is the same as for the spec 03. If you're still looking for a cooler, see my post above. Good luck! And if you find one and want some feedback, we're here to help :)
