New case Help
bharatwaja
431
I have planned on buying the GigaByte 3d aurora 570 for my next build... How is the case? Any good? also airflow wise?
I read somwhere that the fans are all linked together and have a 3-pin connector... where shud we connect this? into the MOBO? the motherboard is Asus Maximus formula or Maximus Extreme....
Zepper
18,998
The 570 is basically an oversized Cooler Master Centurion chassis done up in aluminum. The similar Centurion chassis is very popular and cools well. IDK about the fans, but I wouldn't want them all running at the same speed (unless they are similar to the ones C-M normally supplies with their cases, etc. which barely move any air so need to be at full speed 24/7 anyway) which is why I almost always install a fan controller into my systems - so I can control the fans based on the temp each mostly effects.
. There are plenty of reviews of the 570 around the web. Perhaps more fan info can be picked up there.
I don't know what this is all about, but when you have the 570 in front of you, perhaps it will be obvious:
http://www.gigabyte.com.tw/Fil...hassis_diy_bracket.doc
.bh.
