New case, fan questions/Aio recomendations
ratjacket
120
I got a new 2nd hand case as I might get a AiO water cooler
its the original phantom
http://www.nzxt.com/product/detail/34-phantom.html
looking for fans for the case and possible kraken x60 (would I better to just get a meaty Heat sink and mount my beefy fans on it)
and I don't like what I see :ninja:
I have 6 spare 120mm fans that are quite beefy (were ultra cheap too $4 NZ but had no connectors on the end)
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_1955028_-1
118CFM 8.38 mm H2O, the down side is the dead space in the middle is bigger than most std compu fans (& they use quite a bit more W than std compu fans 8.4W).
1. Would these be suitable for The radiator on push, would I need some sort of shroud options (since large dead space in middle and mounting holes), shrouds adaptors (120-140 or 120-200 for side intake) seem limited in NZ as well as decent fans
If a 140mm will be a lot better about the best I can see so far in NZ is the Akasa Viper, but compared to my 120mm fans seems dismal 110CFM 3.12mm H2O
2. Are there any 140mm High CFM (i.e >118 by a decent amount) fans for my front intake, pressure can be lower since low resistance intake
3. And finally are there any good 200mm fans for pull on the radiator/and or side intake since I have the mount at the top of the case, do they need good static pressure for pull on the radiator (at least higher CFM by a decent margin than my 120mm fans)
Noise concerns are for pussies :eek:
and my computer is situated many rooms away from my displays and input device
Meanwhile my 4770k is dying to be oced but is mad at me for having a stock cooler
ratjacket
120
Decided to go with an air cooler NH-C14
i had to go C-14 as i modded the side panel to take my industrail 120mm fans they are 38mm thick so limits the head room in the case, need 150mm of height or less
i will try and fit 2 of the 38mm thick fans on the C-14 if i can
if i went Aio i wouldnt of had room to use the powerfull 120mm fans in push pull
and since i move my rig on occasion to a friends house i dont want the risk of the Aio springing a leak
i have a 38mm thick 120mm fan on the front intake
modded the case to fit 2x120mm 38mm thick fans on the side as intake (over cpu and ram)
i made a mistake and now my rear exahust wont take a 38mm thick fan aswell due to my mod
i would of changed it to intake aswell, i will just have to use a pussy fan on there now (hopefull it can blow in against all the pressure these fans generate)
and i will use 2 x of the highest cfm 200m fans i can on the top for exhaust
while the 120mm fans are loud it doesnt worry me at home when i take it away to a mates i will just drop the speed on the fan controller to low and its accpetable then
i will post some thermals when i get the cpu heatsink installed, before hand on stock cpu fan the cpu would hit a 100c in 1min on a stress test, in the old case with the side intakes it only hit 80 odd, now shes is modded it is slightly better than before but i dont have all the fans in yet.
