ok im putting my rig into a 21" case now and i need some advice about fan placement and feedback about a little plan i got with the case fans in the front and back, here we go
I got a TT 420W P/S it has 2 fans
I plan to put 2 fans on the back of the case,2 on the front,and i on the window, the fans on the front will bring IN air and the 2 on the back will EXIT air,and the one on the window Im not sure should it be IN or OUT.
let me know if this is a good plan, Now for my next question
the fans on the front and back since there is 2 each both with molex connectors can i splice the wires together and run them off one molex connector or will this split the rpm's in half or will they both operate as usuall.
any help would be great
mOrt
mOrt
