New car LED brake lights are too bright
Discussion in 'The Garage' started by OutHouse, Dec 4, 2007.
  1. OutHouse
    OutHouse Lifer
    Jun 5, 2000
    36,368
    589
    i was behind a new Accord last night at a stop light and i swear those new LED brake lights are way way way to bright.
    anybody else think so?
  2. Crusty
    Crusty Lifer
    Sep 30, 2001
    12,688
    They aren't as bright as all those damn oncoming headlights :(
  3. OutHouse
    OutHouse Lifer
    Jun 5, 2000
    36,368
    589
    I dont see many of those HID headlights anymore, well not like i used to. did the USDOT make the car makers stop installing them?
  4. HN
    HN Diamond Member
    Jan 19, 2001
    8,187
    agreed in regards to the taillights
  5. lokiju
    lokiju Lifer
    May 29, 2003
    18,538
    I concur wholeheartedly.
    Annoys the hell out of me.
    My eyes are more sensitive to brights lights than others I know as it is and at night time while driving, the contrast is nearly dangerous for me.
  6. Mark R
    Mark R Diamond Member
    8,517
    11
    This is why you are not supposed to rest your foot on the footbrake when stopped at lights and there is traffic behind you.
    The correct thing to do when waiting in a line of traffic at night is to use the handbrake.
  7. MegaVovaN
    MegaVovaN Diamond Member
    May 20, 2005
    4,131
    Train light ftw?
    We've seen train horn, now get train headlight?
  8. mobobuff
    mobobuff Lifer
    Apr 5, 2004
    11,101
    I don't mind the ones that are too bright, I mind the ones that strobe and you can see the refresh rate leaving broken up light trails in your vision.
  9. OutHouse
    OutHouse Lifer
    Jun 5, 2000
    36,368
    589
    i have never heard that in my life. did you just make that up?
  10. mobobuff
    mobobuff Lifer
    Apr 5, 2004
    11,101
    *taps his sarcasm meter*
  11. Krazy4Real
    Krazy4Real Lifer
    Oct 3, 2003
    12,207
    49
    Try wearing sunglasses at night time.
  12. Nyati13
    Nyati13 Senior member
    Jan 2, 2003
    785
    Real HID equipped cars are more numerous by the day. The availability of aftermarket "HID-like" lights might be decreasing.
  13. Jahee
    Jahee Platinum Member
    Sep 21, 2006
    2,082
    Welll.. In England they do encourage that. I was encouraged to when i was learning anyway!
  14. Mark R
    8,517
    11
    This was meant to be serious.
    This was a tip about night driving told me by an advanced driving instructor.
    a) You don't dazzle the person behind.
    b) If the car behind gets rear-ended, or otherwise shunts into you, the first thing that happens to you is your foot comes off the brake pedal. If the handbrake isn't on, the car will roll forward and hit the car in front (or roll into the intersection, if you are first).
  15. Aharami
    Aharami Lifer
    Aug 31, 2001
    21,175
    37
    this is true. i see more and more cars outfitted with OEM HIDs. HID kits are decreasing.
    as for the OP, neither LED brake lights nor (properly adjusted) HID lights bother me
  16. Regs
    Regs Lifer
    Aug 9, 2002
    16,615
    11
    lol. I stop behind some car coming to a crawling stop and all of a sudden I feel like I'm getting tractor beamed into a star ship.
  17. boomerang
    boomerang Lifer
    Jun 19, 2000
    18,734
    543
    If i was the last car in a line of stopped cars at night, the last thing I'd want is to not have my brake lights on.
    You won't see me sitting there with the parking brake on. I want traffic coming up behind me to know I'm stopped.
    This is one of the more ridiculous things I've ever heard.
  18. JulesMaximus
    JulesMaximus No Lifer
    Jul 3, 2003
    73,580
    396
    You longing for the good ole days when you could barely see a cars brake lights and there was a chance that your car would explode when rear ended?
  19. Zenmervolt
    Zenmervolt Elite member
    Oct 22, 2000
    24,520
    4
    1) If the person behind you gets dazzled by brake lights the he or she has no business being on the road at night because he or she has obvious and severe night vision problems. If they are distracted by something as relatively dim as brake lights (and yes, even the new LED lights are relatively dim when compared to headlights) then the headlights from oncoming cars must practically be blinding to them, which makes them a danger to everyone else on the road.
    2) If you have a standard transmission and you are hit from behind, your foot will also come off the clutch, at which point the engine will stall and the car will be prevented from rolling forward that way.
    3) If you're hit hard enough that your foot comes off the brake, you're almost certainly going to be forced into the car in front of you even if you had the handbrake on.
    4) If you have an automatic transmission, you end up putting unnecessary wear on the transmission's clutchpacks by shifting out of gear and back into gear each time you stop.
    5) If you have your handbrake on and you need to start moving again quickly, you lose time dis-engaging the parking brake (essentially you are taking away one of your emergency maneuver options).
    Unless you are going to be stopped for an extended period of time, you should have your vehicle in gear and you should be using the service brake to keep from rolling. The parking brake is for parking, which makes the name "parking brake" rather convenient.
    ZV
  20. OutHouse
    OutHouse Lifer
    Jun 5, 2000
    36,368
    589
    i disagree. the new LED brake lights are blinding.
  21. randay
    randay Lifer
    May 30, 2006
    10,570
    7
    he probably just overfilled his brake light fluids.
  22. jlee
    jlee Lifer
    Sep 12, 2001
    48,259
    150
    More blinding than oncoming headlights..?
    How do you manage to go by a lit-up emergency vehicle without crashing? :confused:
  23. OutHouse
    OutHouse Lifer
    Jun 5, 2000
    36,368
    589
    :roll:
  24. mobobuff
    mobobuff Lifer
    Apr 5, 2004
    11,101
    Also a lot of drivers (especially women and especially at night) have poor spatial judgement and cannot tell that a car ahead of them is stopping unless the tail lights get noticeably brighter.
  25. JulesMaximus
    Jul 3, 2003
    73,580
    396
    I thought it was amusing. :laugh::p
