- Jul 11, 2009
- 7
- 0
- 0
Can't get my new system to post. Let me know if you see anything I missed. Thanks for any help.
My issue is no beep codes or digital display codes at all (with barebones components in).
My vid card is 9800GT. Just verified it works fine in another system. My 600w PSU also works fine with different mobo. Eneramx PSU is about 8 years old and all molex but I have all necessary power adapters like 20 to 24 pin main power and 4 pin to 8 pin power adapter.
Fans spin on boot and keyboard lights up once.
I take the memory out I get the expected memory error and beeping.
Tried just one stick of ram in all 4 slots but still no error codes and no post.
I take the vid card out and get the console output "d6" digital code and beeping.
Vid card does have the power plugged in to two molex plugs.
Also my fan2 3pin header does not work for some reason. The fan1 does work.
CPU always stays ice cold to the touch. I do have a large cooler but I should be able to feel some heat near the base after 60 seconds, probably sooner. I can't see any daylight between the hs and cpu so I think it's installed correctly. I verified that pin1 of the cpu was where it should be during installation.
Same results when taking the board out of the case completely.
Tried reseating everthing
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
ASRock P67 PRO3 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Scythe SCMG-3000 120mm Heat Pipe CPU Cooler
9800 GT Silent Cell PCIE 2.0 16x
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
