I have problems installing the 2
1st the zalman I'm installing it on 939 asrock mb
When I tighten the bolts to the end I can still turn it clockwise and counter clockwise a few mm each way
Otherwise it seems to be sitting firmly on the CPU other wise
Is it normal?
2nd the 800gto
The box states it needs a specialized 12v graphics connector
I'm assuming they mean the 24pin pcu
The MB has 20pin connector and I have antec true-power 430
The card has no "standard" external power connector floppy or hd 4pin type
It has a small 4pin connector (like a fan with 3pins type)
There was no power cables bundled in the box
Do I just plug it in PCI express or do I have to connect something to it?
Sry if the questions are redundantly silly I just don't want to fry my new opteron or the graphics card
Tnx
Is it normal?
2nd the 800gto
Tnx
