New build problem ...
hellomcfly
100
so i just finished putting together and installing everything for my new build, seems to be running pretty good
but now randomly the computer will lock up and freeze... the image will remain on the monitor and a steady beep or shriek will come from the speakers... any ideas ?
intel q6600
nvidia 9800gtx
4gigs gskill ddr2 800
wd 640
gigabyte ga ep43 ds3l
corsair 650 powersupply
xigmatek 1294ee heatsink ... great temps - so i dont think it is overheating
mpilchfamily
3,559
Had similar problems in games till i updated the video card drivers.
Go online and get updated drivers. Then log in threw safe mode. Remove the old drivers then install the new ones.
Denithor
6,298
23
mpilchfamily +1
Update all your drivers with the most recent available online and see if that clears it up.
hellomcfly
100
hmmm i had got the newest ones from the nvidia site when i did the install ...
should i try the retail cd ? or possibly beta drivers?
krnmastersgt
2,873
While mpilch only listed video drivers, that was his problem, do what Denithor suggested and re-install ALL your drivers with the most updated versions and make sure they're compatible with whatever OS you're running.
