New BUILD: Not going to POST
superkame
So I got the part and it isnt going to POST.
It powers up and nothing! I took it all apart and to see if any connection was loose.... NADA.... stuck. Any suggestions?
Here is the final specs:
AMD FX-57
Asus A8n-SLI Premium
(2) 1gig Corsair TWINX2048-3200C2 Pro
Antec True Control II 550watt
Maybe the Corsair memory isnt compatible?
I read through this already....
http://www.mechbgon.com/docs/troubleshooting.rtf
mechBgon
Oct 31, 1999
30,699
Do you have the EZ-Plug connected, as well as the ATX12V cable? The EZ Plug is the four-pin power receptacle just above the upper video-card slot on the mobo's surface.
Also, what are the rest of the specs (video cards and stuff) and did you try testing the bare essentials with the motherboard outside the case, lying on cardboard? And I know you probably triple-checked, but if your video card has a receptacle for a power cable, is that hooked up?
rivan
9,677
Define "powers up" more clearly, please... fans (case, and CPU)? disk drives? power light on motherboard (Asus usually has a green LED for mobo power on the mobo itself).
A motherboard with nothing but a speaker (yours might even have a soldered on speaker) attached will post. Take everything out - video, ram, processor and all, and see what it does; if it posts, add things back in one at a time... CPu, then RAM, then video, then whatever else. Describe what it does to us for each step. Connect your drives last, one at a time, starting with the boot disk.
If it doesn't post with nothing attached, and has power (indiciated by the LED, or better, by measuring voltage on your PSU) then it's likely a dead motherboard.
superkame
Sorry about that....I jsut want to see it post
here is more info. I have the Asus Premium with the Fx-57 outside of the box.
I jsut want to see if it will POST. the Cors Twin 3200-PRO is plugged in.
Both the Power cable is plugged into the motherboard. There is a green light on the motherboard.
I will take out the RAM and CPU and see what it does...
drum
6,810
4
you're going to want to leave the cpu in there.
SGPSupraman
20
I had a similar problem, with my ABit board. I removed the Processor from the socket examined the pins and re-seated it and the computer posted no problems. You may want to check that out
Otherwise I'm useless :)
mechBgon
Oct 31, 1999
30,699
You want all three power cables plugged into the motherboard. Also, post your complete specs, start to finish, brand AND model, so we don't have to guess what you've got for hardware.
That is all.
superkame
AMD FX-57 w/ Cooler Master AquaTel Mini 120
7800GTX Nvidia
This is all the equipment i have plugged in....
There are 3 plugs. two for the motherboard and one for the video card. The 7800GTX already have a power port, I dont think i need to plug that in.
- I plugged it in and nothing.
I will try taking out the cpu and putting it back on....
ANother person with the EXACT problem..... No anwer though....
http://forums.anandtech.com/messageview...atid=29&threadid=1655717&enterthread=y
mechBgon
Oct 31, 1999
30,699
You should have the power cord hooked up to the 7800 like this and three power plugs on the motherboard:
1) the 24-pin main plug
2) the 4-pin ATX12V square plug
3) the EZ Plug
This post was brought to you by the colors yellow and black, and the number 23544 :)
