Hi Guys,
I was reading different threads on the forum and decided to register to ask for your help.
I'm building a new setup for 2012 and can't really decide on how to properly cool it !
The build will be:
- i7 2700k
- Asus P8Z68-V PRO/Gen3
- Corsair Dominator 16Gb (4*4)
- WD Black Caviar 2To
- Samsung Internal Blu-Ray Reader
- PNY GTX 460 OC
- Corsair Force Series SATA3 120GB SSD
- Corsair 650 Watts 80 Plus Bronze Power Supply
- Cooler Master HAF-X Full Tower Case
Now, I don't plan on overclocking anything for the first few months but will definitely consider it later.
I've been hesitating between a CoolerMaster Hyper 212 CPU Cooler, or a Noctua D14 or A Corsair Hydro Series ( 70, 80, or 100 ).
What do you think is best suited for my needs ? Price isn't really an issue for me at the moment. If you see any other components that need to be changed, don't hesitate to point it out !
Just F.Y.I, the GTX 460 OC isn't new but I want to keep it for a few more months that's why I didn't go for a GTX 570 or similar.
Thanks a lot for your help
The build will be:
- i7 2700k
- PNY GTX 460 OC
