thindelock
Hello all. I'd really appreciate some help here. I built a new computer, turned it on, all fans and LEDs come on briefly, then the fans all turn off, then it turns back on and stays, but the monitor never shows that it's getting a signal. Monitor is known-good, I can attach it to other computers fine. The case didn't come with a system speaker, so no beep code information.
It's been a few years since I built a system, but I checked my compatibility and cabling a couple of times, everything should be good.
Steps I've tried so far, in order:
1) Reseated memory
2) Reseated power and data cables, including checking all modular connections on power supply
3) Cleared CMOS by jumpers. NOTE: The next boot attempt didn't turn off the fans temporarily like the others had
4) Reseated graphics card. NOTE: After this, the weird double-cycle of the fans started back again.
My problem is, I'm 45 minutes away from the computer part store. Making multiple trips back and forth to get one bit then another is an expensive, time-consuming proposition.
My hunch is, power supply. It's louder than I think it's supposed to be based on reviews. It's 550w, which some online sources say is enough for this sort of build and some say isn't. But again, I want to explore all options before I start running around buying one piece at a time. And unfortunately, I don't have a desktop to salvage parts from, my wife and I have had laptops only for 3 years.
Here's an equipment breakdown:
ASUS P8P67-R3 LGA 1155 P67 Intel ATX Motherboard
Core i7 2600K LGA 1155 Boxed Processor
WD Caviar Blue 1TB 7,200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
Sapphire AMD Radeon HD 6950 1024MB GDDR5 PCIe 2.1 x16
Vengeance Series 8GB DDR3-1600 (PC3-12800) CL9 Dual Channel (2x4GB)
LG GH22NS50 22X Internal SATA Super Multi DVD Drive OEM
Antec Three Hundred ATX Mid Tower Case
Coolmax CUL-550B 550 Watt Semi-Modular ATX Power Supply
Vertex Limited Edition OCZSSD2-1VTXLE1 100GB SATA 3.0Gb/s 2.5" SSD
Any help or advise would be greatly appreciated.
1) Reseated memory
