New build help
WoWNerd
Good Day folk, I am looking to upgrade my PC. Below you will find what I am working with at the moment.
1. What YOUR PC will be used for: Gaming (World of Warcraft Only)
2. What YOUR budget is. 1000$ - 1500$
3. What country Canada
4. Where will I buy the parts: http://www.canadacomputers.com
5. IF YOU have a brand preference. nope
6. If YOU intend on using any of YOUR current parts, Yes CPU if you can suggest replacing other parts let me know.
7. IF YOU plan on overclocking or run the system at default speeds. Yes I will thinker and see if I can oc. I am wondering if the motherboard should be change or will be ok to OC.
8. What resolution, not monitor size, will you be using? I currently have a 1080p but Would it be worth and gaming at 1440p?
9. WHEN do you plan to build it? End of July 2018
10. No software needed.
Current Build
CPU
: Intel Core i5 4670K @ 3.40GHz Haswell
Motherboard: G1.Sniper Z87
RAM: G.Skill RipjawsX 4GB x 2 (F3-12800CL9D-4GBXL) Dual-Channel DDR3 @ 798MHz (11-11-11-28)
GPU: 2048MB ATI AMD Radeon HD 7800 Series (Gigabyte)
Storage:
223GB ADATA SP550 ATA Device (SSD) I wish I could upgrade to http://www.canadacomputers.com/product_info.php?cPath=179_1229_1296&item_id=103623
Is there a newer board I could use with my current CPU would LG 1151 would with my LG 1150 CPU. I think it's a non sense question but hey I am asking anyways.
698GB Seagate ST3750528AS ATA Device (SATA)
whm1974
9,436
1,572
Yes it is worth gaming at 1440p/1600p and easy to do. But I would go with a video card and memory upgrade to your current system. Your CPU is fast enough for what you are doing.
Reactions: Ken g6 and WoWNerd
whm1974
9,436
1,572
I would also upgrade to larger storage devices as well, both SSD and HDD.
richaron
1,357
329
I'm not exactly sure about WoW CPU requirements, but I suspect you're OK on that front.
Maybe you could blow your budget on a big ass monitor (like this one I saw on AT recently) plus mid-range GPU (AMD for the monitor linked above) and you could walk away a happy person.
But you're asking about purchasing about 3 months in the future and a lot can change in that time.
Reactions: WoWNerd and whm1974
whm1974
9,436
1,572
Does World of Warcraft support officially 4K in 2018?
WoWNerd
Very true I will bump the thread in mid July
