gerryd1968
Hi Guy's,
I would like to get some opinions on some MOBO, PSU, CPU, and RAM combinations in so far as the compatibility and performance. i will be using this for gaming and video encoding, i will be using a,
eVGA 256-P2-N516 Geforce 7800GT 256MB 256-bit GDDR3 VIVO PCI Express x16 Video Card
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case
SONY Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
NEC Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE/ATAPI DVD Burner
Microsoft Windows XP Professional With SP2 - OEM
The choices i am looking at for CPU's are:
AMD Athlon 64 X2 3800+ Manchester 1GHz FSB Socket 939 Dual Core Processor Model ADA3800BVBOX - Retail
Or
AMD Opteron 165 Denmark 1GHz FSB Socket 939 Dual Core Processor Model OSA165CDBOX - Retail
I would like to OC later on when i have a better understanding of how it is done.
The MOBO choices are:
ASUS A8N-SLI Socket 939 NVIDIA nForce4 SLI ATX AMD
ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra ATX AMD
DFI LANPARTY UT nF4 Ultra-D Socket 939 NVIDIA nForce4 Ultra ATX AMD
SLI may be a consideration for the future.
the PSU choices:
Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply
Antec TruePower 2.0 TP2-550 EPS12V ATX12V 550W Power Supply
OCZ PowerStream OCZ520ADJSLI ATX, BTX, EPS12V 520W Power Supply
Going a bit bigger to allow for future upgrades
RAM choices:
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TWINX2048-3200
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Platinum System Memory Model OCZ4002048ELDCPE-K
any coments/sugestions would be helpful as this is going to be my first build. My budget is around +/- $1200
thanks
Or
the PSU choices:
RAM choices:
thanks
