New build help ! SSD for OS and Editing Softwares installation!
luctantem
Shall I buy two separate sandisk ssd 120GB each and install OSX in one and windows in another if I want to install two os?
Or go for single 240GB ssd and install both on same drive, which do you think is better?
also what about other programs and software's for editing (Adobe suite all ) , color grading (Davinci resolve), where do I install them?
Plz guide. 🙂
Multiple drives tends to reduce headaches, IME, when something goes wrong. Also OS X can be made to read and write NTFS (should read fine out of the box) with relative ease, and with greater reliability, than Windows and HPFS+.
http://www.macbreaker.com/2012/03/dual-boot-mac-os-x-and-windows-with.html
Apparently it's not hard to set up, either.
Where they normally go, on the partition their host OS is on.
So I keep 240GB seaparte SSD for macOsx and install video and color software and all programs on it
120Gb seaparte SSD for windows only with no softwares in it!
Good way???
