new build critique and help
KLC
258
I'm getting ready to build a new PC within the the next month. My last build, a Q6600, has lasted me for more than 7 years, so you can see that I generally am not a serial upgrader. My philosophy is to try and hit just below the bleeding edge to get good performance and long life without the price premium of the very best.
I use the PC for general web browsing, media consumption, light office work word processing and spreadsheets, and photography using Adobe Lightroom and Photoshop. No gaming at all. Here is what I am considering right now.
CPU: Intel Core i5 6500, it seems to be the best balance of performance and price for what I need. I will use the Intel cooler.
Motherboard: here is where I could use some advice. I will use the CPU integrated graphics. I will be buying a new monitor soon, not sure what right now. I want to preserve all of my options so the mb has to have Displayport as well as HDMI and DVI. I also want USB 3.1, right now I have nothing that demands that, but since I tend to build and use for a long time I want to have the 3.1 option for the future. I want lots of USB ports for the same reason. I have a desk with a built in cubicle for a full sized tower, since there is no advantage for going smaller I'm looking at ATX boards. I'm currently thinking about either the ASRock Z170 Extreme4 or the Asus Z170-A. I've used Asus and Gigabyte boards in the past, never ASRock. They seem comparable although the audio in the ASRock seems to be better. Any comments or suggestions on these or other boards?
Memory: here I need help. I want at least 16gb but I have not kept up on mem speeds. I even went to the ASRock website to look at their memory recommendations, but I'm still not sure what I really need. Again, nothing at the bleeding edge, just good memory for a good price. What do you suggest?
Case: Fractal Design R4 or R5, whichever gives me the best price. I like the sound deadening and the simple design with the ports and power on the top edge of the case.
Hard drive: Sandisk X400 1tb SSD. Again, the bleeding edge would be M.2 NVME, but a SATA based SSD I think will be OK for what I do. Since I have a large catalog of photos I need a larger drive and the price and warranty for this Sandisk make it very attractive.
Power supply: Seasonic SSP-450RT 450W 80 PLUS Gold. I'm going for the reliability of the Seasonic name here, although my current build has a Corsair PS that has been running for 7 years. This is negotiable, if I find a quality name for less I'd change.
So any general comments are welcome and specific comments about the motherboards and the memory would be a big help.
Ketchup
14,559
248
Asus for the board. My last Asus board had so few features but solid as a rock, even today. But my latest board cost about the same as the others and came with some great software.
With the latest Intel chips, the faster the RAM the better for integrated graphics, just don't waste money on sticks that are rated faster than your board supports.
Power supply is great. I like the 80+ units for today's systems.
mjdupuis
55
10
Highest memory speed compatible with your motherboard.
I also like Asus boards, Seasonic PSU's, and Fractal Cases.
I would recommend the NVME PCIE or m.2 storage option for the speed. Go for a smaller NVME drive and route your downloads, docs, etc to a larger slower drive if cost is a concern with the NVME drives.
Tutorial on routing folders to other drives
Samsung 950 Pro
KLC
258
Thanks for the replies. I am more comfortable going with an Asus mb, although the ASRock seems to have better sound and right now there is a $30 rebate on it. With Lightroom, which is a photo database program, you get the best response and speed having the photos and the database catalog on the fastest drive. I could get a smaller NVME SSD, put the catalog on it and put the photos on a large spinning disk and a few months ago I would have done just that, a 1tb SSD was just too expensive. But the Sandisk seems to me to be just what I need for the best LR performance. I'll sacrifice some disk access speed but more than make up for it with faster photo access and editing.
