New build configuration help requested
Eadward1
What do you think about following as a general purpose computer? As one of the main uses, I would do photo and video editing. Likely using Lightroom mainly, but currently use PSP10. I'm concerned about noise but realise this won't be a silent computer, going for fairly quiet.
I'm a noob at pc building so any help is appreciated. Any compatibility issues? Anything I'm missing?
Thanks
Case: Antec 182
PSU: Corsair HX620 PSU
MB: Gigabyte P35 DDR2 MB - GA-P35-DQ6 (rev. 1.x) Intel® P35 + ICH9R Chipset
CPU: Intel Core 2 Quad Q6600 G0 Stepping Kentsfield 2.40GHz 8MB L2 LGA 775 Processor Retail BX80562Q6600 SLACR [GO step from ClubIT.com]
GPU: Gigabyte 8600GTS silent pipe version
Memory: CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
HSF: Scythe Ninja Plus
Fans: Scythe S-FLEX E 1200RPM
OS and Cache HD's: 2x SAMSUNG SpinPoint T Series HD321KJ 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
Data HD's in RAID 1: 2x SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Optical Drives: 2x Asus DRW-1814BLT SATA DVD RW
OS: Windows 64 bit Ultimate
Goo: Arctic Silver 5
mechBgon
Oct 31, 1999
30,699
Welcome to the Forums :) Since this type of topic fits the General Hardware category really well, the thread is being moved from Computer Help to General Hardware, where it should net you some great advice. :thumbsup:
AnandTech Moderator
mechBgon
