New audio setup, no sound.
Shadax
Just got:
Sound Blaster Audigy 2 ZS Platinum
Logitech THX Z-680 5.1 500w system.
I loaded the drivers for the card, plugged in all the speakers and etc hardware. No sound. When I change effects with the external controller, I can hear the speakers click, then hiss for a few seconds (then hiss goes away which is normal). So I know the speakers are hooked up right. I also have the cables from the controller to the card setup right. I check all volume controls: The controller ones, the system ones, all of em. None of them are at low volume or mute. Yet, not even a peep out of these bad boys. I also JUST built my computer and installed windows a few nights ago, so this system is still an audio virgin.
Any advice?
