Yeah, you need to have .NET installed. I had the same error because I forgot to install it first. There's a link right on the same page as the ATi download.
Originally posted by: AtTheGates
People at Rage3D have use the new control panel with 4.9. Do you have .Net installed? There is also a .Net hotfix on Windows Update.
AFTER you install .Net, there is a FURTHER patch available from MS not incorporated into the original d/l
(at least it was the case a couple of days ago) 😉
