- Oct 25, 1999
- 5,462
- 1
- 0
I moved into a new place this month. There is one room that is attached to the kitchen, it's about 12' by 12'. I have my computer setup there, nothing too drastic in terms of power consumption. At certain times turning the computer on, or the overhead light, will blow the fuse for that room. Other times it's just fine (like now).
Problems:
- This is not a heavy power load, Tower, monitor, speakers and lamp and that's it
- When the power does blow, the actual switch on the fuse box does not turn to 'off'. If I turn it off then back on, the room comes back to life.
- I can hear a *fizzle* noise when I turn the fuses on/off at the circuit breaker board - coming from behind it (not sure on nomenclature here) Basically it sounds like there's an electrical crackle coming from somewhere in the wall.
I'm going to call the landlord tomorrow, as this has me a bit sketched out, any advice / input would be appreciated.
So to summarize, the breaker for this room will trip very easily at certain times in a day. Sometimes it is fine, other times you can see the electricity fluctuating in the room as the overhead light will dim then go back to full, then repeat. Sometimes turning on the overhead light will trip the breaker on its own. The actual breaker tripping won't flip the switch to off, when I manually do this and then back to On to reset it, I sometimes hear a crackling electrical noise behind the board with all the switches on it (name?).
Thanks!
Problems:
Thanks!
