NEW ANTEC CASE
cmdrdredd
27,052
357
Originally posted by: Cygnus X1
Lot of people mad that they didn't wait for this before jumping on the P180b. Glad I waited I don't need another box oven like the P180b. Muhahaha!
Yeah the P180 does create an oven for your system. It has lots of fans, but even still..
Navaros
120
I don't get this board.
The other day I needed a good new case and everyone told me buy P180; now everyone is saying P180 is an oven. :Q
How is a non-tech guy supposed to know what's good or not with so much conflicting information on the same board.
TheJollyFellow
723
Not a lot of room in there though, which could be a downside for watercoolers....But with a 200mm fan, who needs water? :)
VinDSL
4,869
www.lenon.com
Hrm... kinda looks like a portable dehumidifier...
When I first clicked the link, the 'gag reflex' started to set in, but I dunno...
Maybe if they painted it yellow, or something! ;)
anandtechrocks
760
Originally posted by: yosuke188
I do not like the side panel. I wished they just kept the solid side doors.
Yea, I agree. I wish there was no window and it didn't come with LED fans. Other than that, I really like it.
soydios
2,708
That looks like a very...niche...case. Stacker wannabe? Definitely.
Lots of holes does mean lots of cooling, but it also means that internal system noise will leak out of the system. Thus, the case will have lower temps than all previous Antec cases, but it won't be any quieter.
As for the looks, I'm not so hot about the black perforated monolith look. My Antec P160 looks really nice sitting under my desk.
RallyMaster
5,581
Even with my crazy mofo tri 120mm cooling system, I still wonder why anyone would need this. Anything past my level is overkill...and that's final.
Madwand1
3,309
Looks like a nice case for a small file server. But how's the HD accessibility? Looks pretty bad from the side -- can the front be pulled off easily to pull out the drive cages?
Don66
2,216
QFT
Madwand1
3,309
The front grills are good for catching the dust before the drive coolers, but the LEDs can be good at lighting up the residual dust (even after dusting). At least some other similar designs have this problem. But it should be easy to swap out the fans.
The window doesn't bother me -- it can give a bit of illusion of space, lower the price at times, and let you see some internal status LEDs through it.
Cookie Monster
5,161
32
86
Whats up with new cases having 200+ mm fans. But this one is more unique, as has one on top. (Mostly its located on the side).
Looks ok, but i think the interior of p180 is more well though of and designed than this one. This case looks like it focuses more on the cooling side of things.
AntecCSR
394
To install/remove the HDs you'll have to remove both side panels, remove 8 thumbscrews that secure the HD cage to the case. Slide the cage forward (you'd want to detach any cables) and you have access to the drives.
Madwand1
3,309
Thanks. If I understand this correctly, "forward" means through the front of the case, so either the front panel detaches, or the grill/bay covers can be removed.
Odeen
4,892
Yuck. Call me spoiled, but, with my P160, I hardly ever need to remove the right (when viewed from front) side panel. Hard drives slide in across, optical drives slide in from the front on rails, 3.5" devices have a removable cage.
I do get on the other side for cable routing, though. Still, two removable side panels is SO 1999.
Madwand1
3,309
Yeah, the 900 doesn't seem great from a drive maintenance point of view. I guess it's tolerable, but it could be a lot better. Even the "lowly" SLK3000B seems to have a nicer drive maintenance system with its sideways removable drive cage.
ND40oz
1,264
Any reason you didn't do it like the Titan's mounting system where the trays slide/lock into place instead of thumbscrewing in place? I really like the way the titan can remove drives from the front pretty easily with just the removal of the single side panel.
