- Feb 22, 2001
- 1,661
- 19
- 81
I have the (infamous?) Abit KT7A RAID, with 2 IBM Deskstar 45's on it. I really want them to be my boot drive, but can't seem to finish the task...
I have ATA RAID IDE turned on in integrated peripherals, and my boot devices are set Floppy, then RAID, then RAID. All good there, like the instructions say. I used the cntrl+h to set up RAID 0 on the drives, this appeared to go fine too.
I had a heck of a time with several drive formatting diskettes, they wouldn't detect anything other than IDE's 1 and 2. Finally I went to the IBM site and found 2 more to try. One saw them as a PCI card add-on, but as two seperate drives. I gave it a shot but it didn't work. The other did in fact appear to work though - saw it as a single 90. Great! Partitioned into 3 chunks, formatted, and figured I was on my way home.
But it's not my boot device, that's where the problem is (It's the only frives I have attached) Normally on any PC I setup I use the hard drive installation disk, and at the end of the procedure it asks for a 98 diskette, and copies files which makes the drive bootable. The only formatting program I found that even saw my RAID drives (as mentioned above) didn't do this last step, so I'm trying it manually now... I have in the past used an old 95 boot disk to do a "sys c:\", which always made my c drive bootable. This time around, that disk won't detect the RAID drives at all, so that's not working. I try my 98 disk, and it sees the drives (c, d, and e), but thinks they are 2 gigs in size, and whenever I try to copy command.com or otherwise over, the system just freezes up totally, power off to reboot.
I feel like I'm so close - I've spent two days searching for FAQ's, boards, etc. Baiscally, I (believe that I) have successfully installed the drives, partitioned them, and formatted them. The BIOS sees them as a pair of striped as well (both are set to master, one on IDE3, one on 4). All I have to do is put the boot files on them, right?
BUT HOW? Obviously some people here have had success, so what's the secret? Can you point me to a particular program that you use? I'm looking for that last step of a bootable diskette, that can find the new drives, and copy the command.com and other bootup files without crashing. If you do this off of a single, "magical" diskette, could you e-mail it's contents to me??? Or point me to where I can download it? Is there some other way around this? So close!?!
My e-mail addy is greg@sallee.org . Any help is appreciated!
