Android8675
I have a system that I recently upgraded with a ECS nFORCE4-A754 mobo and a EVGA 7800GT PCIe card. System is powered with the Enermax mentioned above.
I got one of those 2Molex to PCIe Power connecters, but when I hook everything up, press power, the fan on my mobo stutters for a second, but the system doesn't power on.
Experimenting I unplugged the PCIe card from the power connector and the system powered on (obivously it didn't go beyond that).
So is this the power supply? It's a ATX 1.3, but from the FAQs I've read here, that shouldn't be a problem. The manual says that this mother board "should" work ok with a 20-pin connector.
I'm hoping I don't need another power supply, the +12V rail on this PSU has 33A which I think is higher than average.
I tried connecting the molex connectors to different lines coming from the PSU, no luck there. Since I don't have another video card to test with I can't elliminate the possibility that the motherboard is bad, but if I pull out the video card the motherboard beeps (1 long, 2 short) when powering up. Leading me to believe it's just not getting enough juice.
Will take the video card to work and have IT check it out there.
Any suggestions/confirmations appreciated.
