LTC8K6
Anyone heard of this thing / have any experience with it. The claims just don't sound right to me. 180-200 degrees F is not hot enough to vaporize the contaminants, is it? How would the cotton filter neutralize acids?
http://www.electrolubegreen.com/home.html
The Refiner design is a 2-stage cleaning process:
First Stage Superior Particle Filtration
Oil enters the refiner through a restricting orifice in the bottom. It then passes through a filter element, made of specially blended, compressed long staple cotton. This highly effective filter element traps solid particles down to less than five (5) microns. It neutralizes acids that may be present in the used oil and it also temporarily absorbs a moderate amount of water for a subsequent more even vaporization in the heat-chamber.
Second Stage Vaporization of Liquid Contaminants
The oil then passes through a series of tiny openings, into the upper chamber, where a heating coil in the lid maintains a temperature range from 180° F to 200° F. This temperature is not warm enough to affect the oil itself, but it is the perfect range to cause vaporization of water and fuel contaminants. The stair-step design of the dispersion plate assures a slow even flow of oil to enhance vaporization. The vaporized fuel, water and other contaminants pass to the outside through a vent hole at the top of the refiner, while clean de-contaminated oil is returned to the oil reservoir.
