- Aug 10, 2002
- 5,847
- 154
- 106
NEC 2011 says you need a neutral in each box even if you don't use it. What are you guys doing when wiring up a 3 way switch scenario where the white wire is used as a traveler? Example: http://www.buildmyowncabin.com/electrical/img14.gif The box at the right is technically not compliant because of the absent neutral wire; in this case repurposed. That's my interpretation of the code.
Ignore the code or is this a case where you use 4 conductor cable e.g. 14-4 cable to maintain compliance? The unused wire would get a white piece of tape wrapped around it to designate neutral and then tucked into the box for future use. Or do you guys use the white wire like in diagram above anyway?
