I have an office network w/ two windows 98 Pc's connected to each other via NetBEUI and to a T-1 via TCP/IP. They run through a ethernet hub. The two 98 machines are seeing each other fine and both have access to the T-1 but for the life of me I can't figure out how to get the XP machine on the workgroup!
I want to add the PC running XP Home onto the network. I know that XP home does not support NetBEUI so how should I do this? The XP machine will need to be networked to the 98 machines as well as the T-1.
Should I install the NetBEUI protocol on the XP machine anyway even though it is not 'supported'? Should I make the entire workgroup run on TCP/IP only?
Thanks for any help on the subject.
