- Oct 9, 2002
- 28,298
- 1,235
- 136
I've been using the Phantasy Star Online backdoor to load homebrew code, including the hacked N64 emulator from the Zelda Bonus Disc. It's a lot of fun and I plan to do this a lot, using my Gamecube for several N64 games. I have a dedicated NIC for my Gamecube, and using the integrated LAN (MSI K7N2G-LISR, nforce2) for my Internet connection. My Internet connection is configured for DHCP, and my secondary NIC has a static IP address specified.
The cards are not bridged, so there should be two physically seperate networks. Is there something wrong with Windows that causes the transfer application to fail when the Internet is connected to the other NIC?
I have tried swapping the NIC configurations, just in case the transfer application was defaulting to the wrong connection. Either way, the application still fails when the Internet connection is enabled from the other NIC. The 'cube connection is sensitive to latency, which is why I chose to use a dedicated NIC and crossover cable instead of plugging it into my router. Why would Windows allow one network connection to affect another when they are not bridged?
Windows IP Configuration
Ethernet adapter NVIDIA:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.1.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Ethernet adapter 3com:
IP Address. . . . . . . . . . . . : 192.168.1.100
