Networking Problems
janissary
46
I'm having some connection problems with a computer i have networked. It downloads at maximum speed, transfers files and all that, but it has problems connecting to some servers -- it wont connect on msn messenger, or when i try to list servers for counterstrike, it is unable to do that. The other computer which is the gateway does all this without any problems at all. I used the "Setup home or small office network" option in windows xp. It is a dsl connection so i used another rj45 cable to connect to the other computer.
Lord Evermore
9,558
You'll need to look into issues sharing an Internet connection for particular applications. Some games, some applications, can't work with a default setup due to the address translation being done by your gateway. I didn't think CounterStrike had any issues with it, but the particular setup you have may be special. Search and you'll find lots of discussions of it.
