Networking problem
ilavu
Hi All,
I am in a situation that I can not figure it out and need help.
I have one manufacturing machine with SMC switch(SMC7004VBR). Machine it self is setup for multiple IP address internally.
Machine setup (CAN NOT CHANGE IP):
IP : 192.168.0.2
SM: 255.255.255.0
Gateway : 192.168.0.1
Switch is set with 192.168.0.1
My server IP for the machine(Static) is
192.168.0.129
255.255.255.0
192.168.0.2
I am trying to connect my server to this machine using WAN port on the switch with above info. The problem is I can not change machine ip address(ie: with different ip address, machine will not work) and also I can not use any of the 192.168.0.X(For WAN or Gateway) and my server is setup with default gateway 192.168.0.2.
Any help?
