mcveigh
A friend bought a new HP machine with Win7 home premium.
He uses it at work with a program to track work orders.
under XP Pro on his old PC this program talked to a database on a NAS via a mapped network drive. Everything worked fine.
with Win7 the program initially opens quickly, meaning it sees the database right away but afterwards.... the query's run slow.
doing something like bringing up an invoice to mail takes a minute or two, this used to take a few seconds on the old PC.
Tech support says Win7 is fully supported and should run the same as XP.
Old PC specs:
XP PRO 32bit
P4 3.0GHZ, 1GB Ram, Mcafee antivirus
gigabit ethernet
new PC:
Win7 home prem. 64 bit
I3 330, 6GB ram, MS security essentials
gigabit ethernet
the network is just about 8 pc's on a gigabit switch. DHCP from the router.
Does anyone know if there is a difference in Win7 networking I should look for?
I'm going to uninstall the anti-virus I guess and see if that helps but I doubt it.
Old PC specs:
XP PRO 32bit
gigabit ethernet
new PC:
gigabit ethernet
