I am trying to network two rooms together....
Basically I want to have one jack in each room accessible by a wall outlet. I have an electrician coming (for seperate electrical work) who can run the wire and cut the holes in the walls but the connections will be up to me. I already have a 50' crimped cable that I am using right now, so if possible I'd like to run that in the wall and just connect it to jacks at both ends (not sure if thats possible - are there wall jacks that have female connectors on BOTH sides? --- is this what im looking for? http://shop.store.yahoo.com/trianglecables-site/paskeyjaccat.html)
Anyway, the ultimate goal is to run the cable at one end directly to the ethernet adapter on a computer. At the other end the wire will be run to a linksys wireless router/switch, which will then connect to a networked printer and two PCs.
Any help would be appreciated, I just want to initially be sure that this will work, and that I should just have the electrician run the cable and cut the wholes
