Networking Help Needed!
deviate007
Hello,
I was wondering if anyone could help me with a problem i have with my network. I am running windows 98 SE with internetshare software running (to share my dsl connection)...and this works fine for any other computer which is plugged into the hub...but what is ticking me off is that I can't see the other computer....i can't find it when i try to use find computer...does anybody have any ideas or suggestions?
BCYL
7,803
Are all the computers in the same workgroup with a unique name?
lowtech1
4,644
Do what kgmz & BCYL say.
If you only want to have TCP/IP, then you have to config your IP address and Subnet Mask (Both puters need to have the same Subnet Mask, but diff IP address).
