I am completely new to networking . The reasons I am thinking about doing it are as follows.
1. My main computer interest is flight sims
2. My present computer is a Pll 450 using a TNT 1 graphics card and is due for an upgrade
3. It has a fault whereby I cannot get into the display properties of the graphics card. Many efforts have been tried but I have given up on that
4. and decided on a lGhz,, Nvidia Ge Force GTS 2, 256 Ram system . ( Blow the savings you only live once)
5. The Pll isn?t worth selling, hence I hope to network it with the new system so that I can load the downloaded files from it to my new system ( cheaper than an external zip system ) and I can play head to head sims with my grandson or friends.
My questions are
 Can I ( should I) use the present system as the ?master ? and the new system as the ?slave?, bearing in mind the files are on the present system as are the modem and internet settings ( external USB modem) . Won?t that be easier to have it that way round?
 Can I use the ?slave? to play internet sims thru the ?master ? , and if I do will the specs of the ?master? override the higher specs of the ?slave ?-
 Likewise , will the display fault of the? master ?affect the display facilities in the ?slave?
 If I make the new lGhz system the master , can I still copy the files from my present system to the new one
What do you experts recommend?
Thank uou for your patience and I can see the smiles at the naivete of the questions , but I am relatively old ( still beat most of you at golf though-lol ) and I am no techie. It will take all my efforts to set up a networking kit, even though they spell everything out .
Cheers
My questions are
Cheers
