When I browse network neighborhood on 98se, I see both this machine and the xp one. When I try to add a network place in 'my network places' in xp, I can see the 98se computer which initially has a + sign to expand it. When I click on the 98se, nothing happens. The 'OK' stays greyed out so I cannot add this to network places. Also, when I do browse the 98se from the 98se Network Neighborhood, nothing is there.
Here's what I've done to get this far, a lot of which isn't necessary I'm sure.
The nics are set for 192.168.0.1 (98se) and 192.168.0.2 (xp)
The 98se machine is connected to the internet thru a sb4100 usb cable modem
I can ping both 192.168.0.1 and 192.168.0.2 from both computers.
I can connect to the xp from 98se using ultravnc.
Both the 98se and the xp have the same workgroup name
Both the 98se and the xp use the same logon name
I have installed netbeui on the 98se machine
I have setup home networking on both machines (ics)
If I use analogx proxy on the 98se, the xp machine can connect to the internet (albeit through limited protocols)
I have adjusted zonealarm pro so that nothing is blocked
The xp version is media center edition (sp2), no updates applied yet
The built-in firewall for xp has been turned off
The ultimate goal is to get internet access for the xp computer through internet connection sharing.
Thanks in advance
Thanks in advance
