Networking 7 and XP....Really?
Intexity
299
So I am at a house trying to set up a network with 3 xp machines and one win 7. The printer is connected to the windows 7 machine via usb and and works. With my laptop if i put in the ip address i can enter the windows 7 machine. I can ping the 7 computer from all three computers. But when on the xp machines only the xp shows. The win7 can see and access all the xp's, but not vice versa. I have everything set to share...including dropping the encrytion...but nothing works...I am assuming after exhaustive attempts that it is with the 7 machine and focusing my energy there...any help is greatly appreciated
xSauronx
19,582
4
map a drive? you can do that via ip and just have the share from the 7 box there all the time
JackMDS
29,563
432
Win7 when configured on peer-to-peer Network has three types of Sharing configurations.
HomeGroup Network = Works only between Win 7 computers. This type of configuration makes it very easy to Entry Level Users to start Network sharing.
Work Network = Basically similar to the previous methods of sharing that let you control what, how, and to whom folders would be shared with.
Public Sharing
= Public Network (like Internet cafe) to reduce security risks.
For best results log to each computer's System Screen and set all the computers to be on a Network with the same name while each computer has its own unique name.
http://www.ezlan.net/Win7/net_name.jpg
Make sure that the Software Firewall on each computer allows free local traffic. If you use 3rd party Firewall On, Vista/XP Native Firewall should be Off, and the active Firewall has to adjusted to your Network IP numbers on what is some time called the Trusted Zone (consult your 3rd Party Firewall instructions
General example, http://www.ezlan.net/faq#trusted
Please Note that some 3rd party Software Firewalls keep blocking aspects of Local Traffic even it they are turned Off (disabled). If possible configure the Firewall correctly, or totally uninstall it to allow clean flow of local network traffic. If the 3rd party software is uninstalled or disables, make sure that Windows native Firewall is On .
Networking Win 7 with other version of Windows as Work Network.
In the Network Center, clicking on the Network type opens the window to the right.
Choose your type of Network. Notice the check mark at the bottom, and check/uncheck it according to your needs.
http://www.ezlan.net/Win7/net_type.jpg
Win 7 - http://windows.microsoft.com/en-us/...mputers-running-different-versions-of-Windows
Win 7 Work Network specific folder sharing - http://www.onecomputerguy.com/windows7/windows7_sharing.htm
Vista File and Printer Sharing- http://technet.microsoft.com/en-us/library/bb727037.aspx
Windows XP File Sharing - http://support.microsoft.com/default.aspx?scid=kb;en-us;304040
Printer Sharing XP - http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Windows Native Firewall setting for Sharing XP - http://support.microsoft.com/kb/875357
Windows XP patch for Sharing with Vista (Not need for XP-SP3) - http://support.microsoft.com/kb/922120
When finished with the setting of the system it is advisable to Reboot all the hardware including the Router and all computers involved.
If you have Permission and Security issues, check the following settings.
Point to the a Folder that meant to to be share. Right click and choose properties.
In the properties
Click on the Security tab shown in the pic bellow to the right) and check that the users and their permission (shown in the pic bellow center and left) are correctly configured. Then do the same to the Permission tab.
This screen shot is from Win 7, Vista's menus are similar.
http://www.ezlan.net/Win7/Permission-Security.jpg
In both the Security panel, and the Permission panel you have to highlight each User/Group and examine that the Permission Controls are checked correctly.
When everything is OK, Reboot the Network (Router, and computer).
* Note . The Groups and Users shown in the screen-shoot are just an
example. Your list will look the way your system is configured.
**Note . You have to establish specific users. Everyone means all of the users that already have an account and been established as users. It does not mean Everyone that feel that they would like to login.
***Note. Some of the processes described above are done Not for Windows sake but to compensate for different Routers and the way their firmware works and stores the info about the computers that are Networked.
Intexity
299
thank you...actually figured out the workgroup name was the problem...and voila now i can see the computers...now its down to an error with the driver for the laserjet 4050 via network...oh joys...thanks guys
