Hi, let me begin by admitting that I'm new to the Apple world.  I chose to lave PC's due to so many issues and concerns with security issues...... anyways.... I need some networking help/advice.  My neighbor asked if she can use my wifi to stream tv/movies only. I couldn't say no because I felt bad and didn't want to say i didnt trust them.  So I hooked up a Netgear router for the wifi while connecting my gaming systems by ethernet to my modem
  I tested the wifi from the Netgear system and it seemed to be working.  I stepped a way for a while and decided to check it again & was able to connect to the NETGEAR but not the internet anymore
..  I know I made no changes but couldnt find the problem until i ran the network diagnostics on my MacBook
.  it created a diagnostic log and suddenly repaired the connection. Is it possible the neighbor was trying to access my local network and caused problems to the wifi?
  how do I find something like this and is there a way to give her access without exposing any of my devices?
 and is the way ive chosen to do it even protecting at all??
Should I get an Apple airport and would this be the best way to have my local network safe while allowing my neighbor the ability to stream?
 Facebook
Facebook Twitter
Twitter
