Hello,
I have three computers which connect to a single cable modem through a hub, and I wish to work with them all in the same home network.
The problem is, that the modem gives two of the computers IP configuration (the IPs are DHCP) with the same default gateway, which means they're in the same network, and the third PC gets a different one, and can't join the network.
I tried to restart the modem, or obtain a different IP through "ipconfig/renew" in the command promt, but nothing helped. The modem probably has some kind of memory, and it gives each computer his old IP time after time.
The modem is Motorola SURFboard SB4200i. Maybe someone knows how to enter its configturation and restart its IP memory?
Thanks,
Guy.
Thanks,
Guy.
