Network Problem
ByacoX
4
I seem to be having some problem with my network, i'm broswing the internet and i have to use Repair in Network Connections about every 30 seconds or so for me to be able to acces the internet.
On my linux partition i don't seem to be having this problem so i guess it must be something with windows, im currently using Windows XP SP2 Profesional.
any ideas?
Harvey
Administrator<br>Elite Member
73
Check for driver updates for your router. If that doesn't help, call your the net router manufacturer's tech support. It's probably a toll free number, and they often have alternative settings for specific setup related problems.
ByacoX
4
not wifi
im seeing this errors in the event viewer
DCOM got error "The service cannot be started, either because it is disabled or because it has no enabled devices associated with it. " attempting to start the service wuauserv with arguments "" in order to run the server:
{E60687F7-01A1-40AA-86AC-DB1CBF673334}
and this warning is showing up alot, most of the time in groups of 5
Your computer was not able to renew its address from the network (from the DHCP Server) for the Network Card with network address 00508DE7C992. The following error occurred:
The semaphore timeout period has expired. . Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
