Network printer using NetBEUI protocol, is there a way to have a DOS program print to it.
IsOs
This is Windows NT 4. Windows programs can print to this printer without a problem. I need to have an old DOS program do some printing. Is there a way to set Windows NT4 to use this network printer for DOS?
Try > Net print \\computername\printer lpt1: in a dos prompt.
You should also be able to do this from the GUI, but I can't tell you off the top of my head.
Good Luck;
Doug
Thanks. That guided me. I used the Net use lpt1 \\computername\sharename and it's working.🙂
