Network help
gyrogypsy
Good Afternoon All,
I am in need of some help and advice. I am no network pro, but I know the basics and that is why I am asking for help on this issue.
I currently have two separate networks, each with their own router and DHCP servers on 172.16.0.XXX and 172.16.10.XXX (using these network addresses for a reason which I will not go into detail why here).
I need to be able to connect both networks together so I can access each network resources from either network. My problem is this - when I connect the two together, the 172.16.0.XXX picks up 172.16.10.XXX addresses! I am pretty sure that this is a simple problem to solve, but like I say I am no expert and I am hoping that someone out there is.
Very much appreciate the help...
Gyro
Or setup the routing rules on the two routers to route traffic to the other network, which'll be a peach with NAT going on.
Better option, if you have more than 1 resource between each network you want to access (it is easy to do with port forwarding and routing tables for a single resource/resource type), is getting a router that supports more than 1 /24 IP range and run it for both LANs.
Or as Jack mentioned, bridge them using a dual NIC machine.
