I have a peer to peer network running on win98se (all boxes). I am using a linksys befsr41 (cable modem).
Here is the deal, a couple of days ago, I started getting some weird file corruptions when I tried to pull image files from my file server box to my main box. Images would come over half green or half of the image was missing. They are fine if you view them on the file server. Also, if I try to pull setup files from the file server, they are always corrupt however, if I run them on the file server they are fine. To make matters more confusing, if I download a file directly to my main box it runs fine , however, if I download it to a mapped drive on the file server it gets corrupted.
Both boxes are overclocked however, I have tried them at stock speed and there is no difference.
I have tried everything I can think of replaced the NIC's, uninstalled and reinstalled tcp/ip, netbeui etc. etc.
The boxes are as follows:
File Server: a7v, duron 700 @ 1000 (10x100), dlink dfe530tx+, promise pci raid controller with 2x ibm 7200rpm 45GB drives, Generic 384MB SDRAM
Main Box: a7v133, tbird 1333 @ 1522 (145x10.5), dlink dfe530tx+, WD 7200RPM 10GB HD, Maxtor 7200RPM 20GB HD, 256MB Mushkin Rev 2 SDRAM.
Any and all suggestions/help is appreciated.
