network connection monitoring
quanttrade99z
123
Hello,
Can anyone recommend a robust software app which monitors your network connection? on Windows PCs... (if no good apps for Windows, we could have a dedicated LINUX machine, but not our preference unless you strongly advocate)
I run a small trading group, and live in fear of our internet connection going down and no one noticing... I'm looking for an app which checks the connection and can do things (like play a sound file) if the connection goes down...
even better if there are lots of fine tuning options... i.e. I don't want to play the sound file if the internet connection is down for 1 second... but I do want to play the sound file if the connection is down for 30 seconds, etc.
Thank you very much!
